Duner
looking at the picks its hard to tell if the chassie is short to the body
rear apears to be in the correct placement
front a little hard to tell to see if the center section chassie hump is to far forward or backward
here is the bisness end of what needs to be done to correct the length
strip it down cut those pans out leaving a bare bones chassie
(skill saw with mettal blade from bottom, then go back with air chisel to remove last bit)
cut that rear torsion out at the weld seam the PO made.
get new IRS torsion (your gona wish you did later on)
tack in to proper length with body on
remove body weld up solid.
I think it would be kinda neat to have a type III front end
definatly a class winer at next years blast. LOL
I would love to come by some time and look it over with ya.
oh and dont wory about those pans some of our cars dident even have pans.
PS could you get us a side shot of the car with the body on it
I believe this whole thing started due to you saying the front wheels looked a littel far back in the wells correct?
