Does anyone (David O.) know which line goes to the filter inlet and outlet? There is one line that comes off the block and one comming off the oil pump.
The line from the pump housing goes to the inlet of the oil filter and the other one goes from the outlet side of the oil filter to the fitting in the block, filter is the same as the rabbit. (or something equal to it)
