by Texasbuggys » 22 Mon May, 2006 7:27 pm
Gary, are you required to run electric wipers? If not I can offer you a cool clamp on mount that is easily removable. No wires and interference problems. I have installed the super speedo with no problems, center the speedo and drop down as low as you can without cutting thropugh the bottom of the dash. Of course double check rear clearances. Also two types of wiper motors so you need to check which you have to clear the speedo.
