I am in the process of running brake lines and it's been real hell
has any one used the vinyl brake line kit with compression fittings?
I have it and a stainless kit as well and there doesn't seem to be enough fittings to make the brakes connect together.
here's what I have so far.
front brakes are almost connected ( I also used braided lines for the flexible lines) but I have three t's in the front because of the park lock (instead of the e-brake handle) I have to put the brake switch in the front so the brake lights don't stay on while the park lock is on.
I can't seem to find any fittings at any autoparts store that fit any of the t's or braided lines. is there any place out there where I can buy just compression fittings that will fit any of the original brake parts such as drums or braided lines.
it seems that 1/4 inch is to big and 1/8 inch is to. 3/8 seems to fit well but I can't find any 3/8 by 3/8 comp.
somebody help me before I go sane.
mike
