Well got to work on the Rockford Stereo Bug
The body work and paint was done about 5 years ago and it was pushed in a barn. I noticed it and we struck up a deal. I am swapping out the semi-auto to 4-speed and welded in new front tranny mount. Building a 200 amp stinger alternator mount running a serpinetine pulley setup.
The rough plans for this car. Well as you can see the rear three windows have been welded shut for better sound out the front, the rear decal has not be put on yet to simulate a rear window. Going to be loaded with Rockford stuff and 10-12 15" subs and 10 pairs of mid and highs. It has been sprayed inside all over with Rhino Lining to help on rattles and is 1/4" thick in some places. It has steel braces weled in for walling it out. The fenders have been shaved and have flush mounted led taillights in them. Running Weld wheels all the way around. Probably going to convert over to 4 wheel disc brakes also. It should be a red rocker for sure.
